Aiptek Go HD preset? at DVinfo.net
Final Cut Suite
Old September 17th, 2007, 06:04 PM   #1
What preset could I setup in FCP 5.1 with clips of these properties:
<img src=http://www.stevenunez.com/GoHDMediaProp.jpg>
That is the property of clips produced from the Aiptek GO HD camcorder. I'd like a sequence preset that would allow for straight imports into the time line w/o rendering each clip.
Thanks guys
steve@stevenunez.com
Steve Nunez-New York City
www.stevenunez.com
Steve Nunez is offline   Reply With Quote
Old September 18th, 2007, 07:20 AM   #2
I believe the Aiptek's are AVCHD (Or just h.264?)? In which case, your footage would need to be converted first. FCP cannot use AVCHD footage on the timeline.
www.mattjohnstonrally.com
Matthew Johnston is offline   Reply With Quote
Old September 18th, 2007, 02:25 PM   #3
No not AVCHD. It's a .mov file with these properties-
www.stevenunez.com
Old September 18th, 2007, 02:48 PM   #4
Hmm, I'm confused now. I thought Final Cut Pro 5.1 (or 6 for that matter) wouldn't even touch MPEG 4, H.264, or anything of the sort. But I was inspired by your idea, I went and created a preset that would conform to an H.264 trailer I downloaded from Apple. I threw the H.264 video on the timeline and could edit without having to render! Why then, can't FCP edit AVCHD if you made some sort of preset for it? Isn't AVCHD just H.264?
Anyway, back to your point, is there a way you could post a raw clip on here so I could try and work on a preset?
Chris Harris is offline   Reply With Quote
Old September 18th, 2007, 03:30 PM   #5
Well, it says right there in your screenshot that it's AVCHD (under Format). You'll need Final Cut Pro 6.0.1 to transfer and capture and I believe it only works on Intel Macs.
See this support doc from the apple site:
http://docs.info.apple.com/article.html?artnum=305997
Best,
Dino Leone is offline   Reply With Quote
Old September 18th, 2007, 06:35 PM   #6
For the record h.264, AVCHD and MPEG-4 Part 10 are exactly the same thing.
No wonder there is so much confusion!
Justin Ferar is offline   Reply With Quote
Old September 18th, 2007, 06:43 PM   #7
So if I can edit a H.264 trailer downloaded from Apple, why can't I edit AVCHD?
Old September 18th, 2007, 07:12 PM   #8
Steve, I downloaded a clip from another user to try it out, and I found a setting that works, although the audio still needs to be rendered.
Frame Size: 1280x720 HDTV 720p (16:9)
Pixel Aspect Ratio: Square
Field Dominance: None
Editing Timebase: 30
Timecode Rate: Same As Editing Timebase
Quicktime Video Settings
Compressor: H.264
Audio Settings
Rate: 48 kHz
Depth: 16-bit
Config: Default
Give it a shot and tell me if it works for you. I just don't think Final Cut Pro is a big fan of compressed audio. It doesn't take too long to render that audio though.
