FCP effect at DVinfo.net
Final Cut Suite
Old September 20th, 2007, 07:45 PM   #1
FCP effect
Anyone know an effect for "ghosting" an image - for instance; a dancer moving at 80% speed while her movements have "trails".
Charles H. Jones is offline   Reply With Quote
Old September 20th, 2007, 08:23 PM   #2
Effects>Video Filters>Time>Trails (and maybe the other two)
You can also do this by duplicating the layer (possibly multiple times) then offsetting it a few frames and changing the opacity as desired (as well as perhaps adding blur).
Daniel Ross is offline   Reply With Quote
Old September 20th, 2007, 08:55 PM   #3
don't have that one...
is it possible that you have some third party plug ins installed? Because I don't have "time" under video filters.
CJ
Old September 20th, 2007, 09:14 PM   #4
Look again...I found it near the bottom of the hierarchal list of effects.
nearsightedproductions.com
Joseph Hutson is offline   Reply With Quote
Old September 20th, 2007, 09:17 PM   #5
I'm absolutely sure I don't have it. Now I feel cheated!!
Old September 20th, 2007, 11:15 PM   #6
What version of FCP do you have? I'm using 5.1. Maybe it moved. (Or, if v. 4 or before, might not have it.)
If you still can't find it, maybe you should use the method I described before with layering.
Old September 21st, 2007, 12:56 AM   #7
I have FCP 5.1.4 - I was able to get close enough with motion blur. Thanks Daniel - on both problems.
CJ
Old September 21st, 2007, 10:08 AM   #8
See this attachment. I can't believe you don't have it if you have 5.1.4. I do too, and I haven't installed any external plugins.
Old September 21st, 2007, 10:30 AM   #9
I would like to have that "trails" filter too - but I don't - see below:
I have FCP v5.1.4. What's going on here, anyone?
( I also notice I haven't got some others shown above too: like the "Tiling" group? )
Martin at HeadSpin HD on Blu-ray
Martin Mayer is offline   Reply With Quote
Old September 21st, 2007, 10:44 AM   #10
That's weird. The only external plugin in my list is a demo from RE:Vision.
You have a lot of plugins there, so maybe it got readjusted as you installed them?
I didn't do anything special with this. Just installed right from the CD.
I have FCS 1. Do you guys have the standalone? (Do they even make a standalone of FCP now or just FCE?)
Old September 21st, 2007, 10:55 AM   #11
Just searched the PDF manual for "trails" and then "tiling" - found nothing either time. :(
This is standalone FCP v5.1.4. Maybe these were introduced with the FCS bundle?
Hmmm. Just found this article which implies "Trails" came in with v.5.1.2. I must investigate further...
I wonder if it's related to the fact that I am running an older machine (G4 Dual 1.42GHz), which won't, for example, run Motion?
Old September 21st, 2007, 11:50 AM   #12
Strange!!!
I have trails, and Tiling which consists of two filters.
This is so STRANGE!!!
check out nearsightedproductions.com
FCP effect-tiling.tiff
Old September 21st, 2007, 11:59 AM   #13
Go Go Godzilla
Images: 15
Make sure you have "All" filters available; see attached.
Old September 21st, 2007, 12:03 PM   #14
How do you post thumbnails, instead of attatchments on DVI?
Old September 21st, 2007, 12:13 PM   #15
I do. Curiouser and curiouser.
