MacBook and FCP 6: Be honest, am I stretching? at DVinfo.net
Final Cut Suite
Old November 10th, 2007, 10:46 PM   #1
MPS Digital Studios
Every time I've opened FCP 6 (specifically with an 87 minute HDV feature converted ProRes 422), after a few minutes, it says I'm out of memory (in both Tiger and now Leopard). And I can't see anything in the Viewer or Canvas.
So, with my 2.16 Ghz MacBook with 1 GB of RAM (I have 2 GB modules on the way) and Leopard, any thoughts why this keeps happening?
1. Will it stop when I double my RAM to 2 GB?
2. I never wiped the MacBook when I bought it--I just installed all my software. Should I have wiped it and started clean?
3. Am I stretching it by having FCP 6 on a MacBook, or do I need to do something different? Is it the HDV-converted-to-ProRes 422 what's hurting it?
Heath
My Final Cut Pro X blog
Old November 11th, 2007, 12:24 AM   #2
I'm honestly surprised it waits a few minutes before running out of memory. :)
With my Adobe windows machine, I started with 1gb, tried HDV and Cineform both, and my computer was hating life. It may not stop when you get an extra gig, but it definitely can't hurt. ProRes vs HDV can't be helping, either, just due to the increased file size/data that must be cached in RAM to play back. ProRes is probably quite a bit harder on memory/HDDs, though easier on your processor.
Since it's on the way, I'd give it a shot with the 2gb with fingers crossed... hopefully might work out for ya. :)
Carl
Carl Middleton is offline   Reply With Quote
Old November 11th, 2007, 12:37 AM   #3
MPS Digital Studios
I think it will, to be honest. I had a MacBook Pro that was the same speed with 1 GB, and it was a nightmare. I quickly added another gig and life was swell.
I had no issues with shorter ProRes projects.
Heath
Old November 11th, 2007, 12:41 AM   #4
Macbook Pro 2.33 ghz, 2GB ram, runs FCP just fine. And other stuff open, and other intense programs, all simultaneously. (AE, FCP, PS, etc.)
It will get slow after you have enough open, but I've never actually had it run out of memory-- stall out with way too many things open and have some apps quit themselves, but never give any memory error, especially in FCP.
Daniel Ross is offline   Reply With Quote
Old November 11th, 2007, 01:07 PM   #5
My Macbook runs FCP 6 jsut fine with 2 gigs on standard footage. However, with HDV the minimum ram is 4gigs, it says so on the system requirements listed on their site. This is probably your problem. A cheaper answer would be the new IMACS over the macbook pro's.
Jason Bowers is offline   Reply With Quote
Old November 11th, 2007, 02:32 PM   #6
MPS Digital Studios
I've used HDV with only 2 GBs on a PowerMac G5 without much problem, but I may stick with an intermediate codec for a while. I'm going to be doing a fairly large edit soon, so I may just drop cash on a low-end Mac Pro.
THANKS!
heath
