Mac DVD printing label software - Page 2 at DVinfo.net
Final Cut Suite
Old December 4th, 2007, 02:32 PM   #16
Well it has the same problem that sure thing has it won't print close to the hub. I have been through the settings but have not found the solution.
It is very basic software.
Paul Cronin
www.paulcroninstudios.com
Old December 4th, 2007, 03:57 PM   #17
Also I can not set up a burn/print I have to do each on their own.
Paul Cronin
Old December 4th, 2007, 08:18 PM   #18
When the print box comes up look for "Publisher Settings" in the pull-down menu in the box. There you can adjust print quality, ink levels and how close to the hub it prints. I would suggest not printing right to the edge of the printable surface as you can get ink on the plastic which will not dry.
Old December 4th, 2007, 08:20 PM   #19
That is another program called "Discribe Robot" that controls the burning and can also print if you have a .bmp of the DVD print artwork ready from Discus. Discus will make a .bmp when you save the file.
Old December 5th, 2007, 10:58 AM   #20
Thanks William but I can not seem to find "Publisher Settings" in Discribe Robot. Could it be that I only have the downloaded version not the Demo but the downloaded version. Do I have to wait till the disc comes?
Paul Cronin
Old December 5th, 2007, 04:19 PM   #21
Thank you all seems to be working well I just burn/print 10 DVD's.
Paul Cronin
Paul Cronin is offline   Reply
