Getting OMF'd sound back in at DVinfo.net
Final Cut Suite
Old June 29th, 2003, 04:32 PM   #1
Hello
I can't seem to find the answer to this question anywhere so maybe I'm missing the point.
Assuming I export my audio tracks as an OMF file, then import this into my audio editing s/w and sweeten it, how do I get that sweetened sound track back into FCP and my sequence?
Cheers!
Simon
Simon Davies is offline   Reply With Quote
Old June 29th, 2003, 07:16 PM   #2
Warden
It would need to be sweetened in a program that supports OMF, like Pro tools. After sweetening, import the file back into FCP.
Jeff Donald
Carpe Diem
Old June 30th, 2003, 05:07 AM   #3
OMF Import
Unless I'm missing the option though I don't see any file/import/omf ? ? ? Am I really missing something here?
Old June 30th, 2003, 09:51 AM   #4
Warden
You have a file that you know is OMF and it doesn't appear when you select <Import>? I don't use ProTools any more so I'm not sure I'll be much help. I think on Avid I could drag and drop also. Have you tried that?
Jeff Donald
Carpe Diem
Old July 1st, 2003, 02:27 PM   #5
Omf'd
I tried this:
1. Created a short sequence
2. Exported the audio to the desktop as an omf
3. Created a new sequence
4. Tried to re-import the omf file and got the message: error, unknown file.
I tried to import back into the original sequence too, on new audio tracks, this didn't work either.. ..
I don't see an option to import files of type 'omf' .. ..
Old July 1st, 2003, 03:38 PM   #6
What is the advantage of OMF vs. say, uncompressed AIFF?
Curtis T. Stoeber is offline   Reply With Quote
Old July 2nd, 2003, 04:27 PM   #7
google it
I did a quick google search on
audio fcp omf import
and got back many results including
http://www.lafcpug.org/fcp2.0page3_review.html
check it out
on the Internet, when you get where you're going you still don't know where you are
Bud Kuenzli is offline   Reply With Quote
Old July 4th, 2003, 05:24 PM   #8
OMF'd
Thanks for that Bud, it's a great article.
I have to say I'm still mystified though, it doesn't tell you the exact process of how to re-import the audio, only that the audio will be a stereo pair ready to drop back into your sequence and output with the video.
From this would I be right in supposing that the stereo pair is actually re-imported back into FCP as a WAV file, which is then dropped in on L & R audio tracks in an overwrite edit?
From everything I've read this seems more and more likely to be the case.
Cheers
Simon
