Motion - No File Browser Window at DVinfo.net
Final Cut Suite
Old February 22nd, 2008, 06:43 PM   #1
Greetings!
I have finally made the switch to FCS 2 after years on a trusty M100 - so I am pushing my way up the learning curve.
I have run into an issue with Motion where the File Browser Window will not open. I have been back and forth between Motion and FCP numerous times today with no problems. I recently went back and opened Motion and the File Browser Window is not opening. I am running two monitors, and have tried switching back and forth with the default layouts and with the one I saved which spread the windows out over two monitors. I have also gone through the usual Window menu and choices to "show" file browser, but it does not come up.
I am on a 2 x 3GHz machine running 10.5.2 and Motion is version 3.02. Also did all my software upgrades and fixed permissions.
Any thoughts?
Dave
David Decker is offline   Reply With Quote
Old February 22nd, 2008, 08:05 PM   #2
David,
Go to Window>File Browser...or Cmd-1.
Cheers
WeeHan
Yeo Wee Han is offline   Reply With Quote
Old February 22nd, 2008, 08:29 PM   #3
Hi WeeHan,
Thanks for your reply. Yes, I have tried both of these suggestions, as well as the File Browser button in the top portion of the viewer window - but the File Browser still does not open. I just restarted my machine after your reply, and still no success.
Just to recap, I have tried going back to the default program layouts, as well as the one I created, updated all software, restarted numerous times, and repaired the permissions.
Weird!
Old February 23rd, 2008, 12:55 AM   #4
David,
It looks like a reinstall might be in order.
Sounds like something went south...
Good luck,
(another) David
David McGiffert is offline   Reply With Quote
Old February 23rd, 2008, 08:30 AM   #5
Really weird David! Looks like a reinstall is unavoidable.
Cheers
WeeHan
Old February 23rd, 2008, 02:24 PM   #6
forgive my ignorance - but this would be a reinstall of just Motion, yes?
Also, do I need to un-install before I reinstall?
