First Time set up - ProRess 422? at DVinfo.net
Final Cut Suite
Old May 4th, 2008, 12:09 PM   #1
I just got my Mac Pro and installed Final Cut Studio. I also installed the Intensity Pro Card for HDMI imports.
I have not installed the drivers for the Intensity Pro Card yet because the instructions say to make sure that I set up Final Cut BEFORE the drivers are installed.
When I open Final Cut it asks me to choose a preset. I have yet to find any ProRess 422 option that everyone keeps talking about!
I'm I missing something here?
Sony HDR-AX2000 • Mac Pro 8 Core w/30" Cinema Display & Final Cut Pro X
Johnnie Caraballo is offline   Reply With Quote
Old May 4th, 2008, 06:14 PM   #2
Assuming you have Final Cut 6 you will most likely not see it in the easy set up menu until you install the intensity card. For easy set up choose the format that matches your footage, then set your sequences and renders to pro res. You can also capture via pro res but I recommend for things like hdv to just set your sequences to pro res.
James Brill is offline   Reply With Quote
Old May 11th, 2008, 07:10 PM   #3
Install the drivers
ProRes is an Apple codec not a Blackmagic codec. If it's missing there's a different reason. I think I remember initially not seeing ProRes in the easy set-up list but it's everywhere else (Sequence Settings/ Capture Settings).
If you've let Software update run since installing FCS, I think you're as far "set-up" as Blackmagic feels is appropriate to install the drivers. They don't require that you have a working project in place, just the software.
It's a great set-up you have there.
Paul E. Coleman is offline   Reply
