iMAC Language Options at DVinfo.net
Final Cut Suite
Old May 10th, 2008, 05:05 AM   #1
I have the possibility of getting a good deal on a new iMAC.
But the problem is I'm buying it in France.
So it will be in French.
My question is is this easy to change to English if the OS has been already installed in French?
Simon Duncan is offline   Reply With Quote
Old May 10th, 2008, 06:51 AM   #2
Go Go Godzilla
Images: 15
In system preferences under the "international" tab you can set the primary language for the OS, finder and the rest of the user interface.
Old May 10th, 2008, 10:39 AM   #3
So I should be OK if I pick up this French iMAC?
Meaning to change the language settings to English should be possible!
Old May 10th, 2008, 05:41 PM   #4
Yes Simon.
The language the computer displays has NOTHING to do with the hardware.
It's all about the software.
And on Macs, the OS software is compatible with most modern languages.
Bill Davis is offline   Reply
