MX02 experiences thread? - Page 2 at DVinfo.net
Final Cut Suite
Old October 16th, 2008, 02:03 AM   #16
The MXO2 is an I/O device so also does Output. You can use it to monitor in real time or play back to an HDMI display. The "2" doesn't do scan conversion, but then I don't believe it would have to when you connect it to a HDMI display that supports the broadcast standards.
The MXO connects to a computer monitor via DVI.
George/
George Kroonder is offline   Reply With Quote
Old October 16th, 2008, 05:53 AM   #17
Thanks George that is the same information I have read. For now the MXO is the right tool for me.
Paul Cronin
www.paulcroninstudios.com
Old March 16th, 2009, 08:34 PM   #18
DV file size is 3 times larger through MXO2
I just captured an hour of DV footage through my Matrox MXO2 to my Mac Pro. It took up 38 GB, which is about 3 times more than if I'd gone straight from my DV deck to the computer via Firewire. Anyone else have a similar experience? What gives??
Patrick Mongoven is offline   Reply With Quote
Old March 17th, 2009, 12:47 AM   #19
What capturing settings are you using?
-Andrew
Andrew Kimery is offline   Reply With Quote
Old March 18th, 2009, 10:17 AM   #20
In FCP 6.0.2, I used the Easy Setup called Matrox MXO2 - DV NTSC 48kHz.
