Apple Compressor Gone?
My compressor software of Final Cut Studio simply disapear... I can open the software, but only can see the finder bar (with compressor menu), and i can make appear only some windows... Can anoyone tell me what can i do? (i already re-installed the fcp) (i made an update...) and the first time than i installed the suite (when i bought the mac book pro the compressor worked perfectly..)
http://img232.imageshack.us/my.php?i...icture1cb4.png Everytime i open the software, i can see only the top menu, and i go to WINDOW and mark:Show Inspector, Window, Preview, Destination and Settings... Thanks.. |
Compressor is a little weird with windows. I wish they would simply dock everything into one window and be done with it. Trash your prefs should do the trick. Or Windows>Layout Standard and then pick one of the right layouts and you'll be all set...
Noah |
In all honesty I hope Noah is right because I had the same problem with Compressor and Leopard. I ended up reverting back to Tiger. Good luck.
P.S. Maybe take this as an opportunity. to discover the other compression suites like Episode Pro |
Noah |
I symply unistalled all fcp suite and re-installed again.. The compressor now its ok...
| All times are GMT -6. The time now is 07:48 PM. |
