Audio level for whole track in FCP at DVinfo.net
Final Cut Suite
Old September 2nd, 2008, 06:56 AM   #1
Hi,
I wonder how I can adjust the audio level for a whole track in Final Cut Pro. Adjusting the track level in the Audio mixer only affects the clip where the playhead is.
Urban Skargren is offline   Reply With Quote
Old September 2nd, 2008, 07:52 AM   #2
Select all the audio clips in the track you want to adjust, and use the menu Modify:Levels... ?
Martin at HeadSpin HD on Blu-ray
Martin Mayer is offline   Reply With Quote
Old September 2nd, 2008, 10:04 AM   #3
Images: 32
Or you can use copy then Paste Attributes to copy the Levels.
"Ultimately, the most extraordinary thing, in a frame, is a human being." - Martin Scorsese
Michael Wisniewski is offline   Reply With Quote
Old September 5th, 2008, 12:18 AM   #4
Adjusting the Master Level of Your Sequence
The Master fader raises or lowers the combined output level of all the tracks in your
sequence at the same time. However, you should wait to use the Master fader until you
have set individual track levels. Once the Master audio meters show acceptable levels
throughout your mix, you can use the Master fader to increase or decrease the overall
level while retaining the same relative mix.
Jon Goulden is offline   Reply
