Best FCP HDV 50i/25p - 25p output workflow? at DVinfo.net
Final Cut Suite
Old December 13th, 2008, 05:26 AM   #1
I am working on a project which has a combination of 50i and 25p footage shot on a Canon XH-A1.
I want to output 25p content but I am not sure on the best workflow. One method I am using is setting the timeline to progressive under the advanced settings with a field dominance of none. This way I seem to be able to have a progressive timeline with the 50i footage deinterlaced.
I want to check with people here to see if there is a better method of doing this. I am afraid that the interlaced footage on the progressive timeline might not be producing the best results.
Andy Yoong is offline   Reply With Quote
Old December 14th, 2008, 03:15 PM   #2
re
i capture 25p but have always had the field set to upper, is this wrong then for 25p???
Luke Oliver is offline   Reply
