editing time base final cut at DVinfo.net
Final Cut Suite
Old January 2nd, 2009, 02:24 PM   #1
editing time base
if im shooting 50i on my sony v1 do i need to change the editing timebase in the sequence setting to 50 or 25???? im confused
would love an answer for this
Luke Oliver is offline   Reply With Quote
Old January 2nd, 2009, 03:32 PM   #2
50i is 25. Or to put it another way 50i (interlaced frames) is equal to 25 (fps - frames per second). There are 2 fields per frame so... 2 fields X 25 fps = 50i
"The good thing about science is that it's true whether you believe it or not." Neil deGrasse Tyson https://www.nautilusproductions.com/
Rick L. Allen is offline   Reply With Quote
Old January 2nd, 2009, 03:53 PM   #3
Luke: if you're recording in HDV at 50i, you should be using the HDV 1080i50 Preset. The 25 preset is for progressive scan material.
