Out of Sync at DVinfo.net
Final Cut Suite
Old February 7th, 2009, 04:10 AM   #1
Out of Sync
Hi
Anyone ever encountered any problems like the following? :
I have a sequence in FCP that is a 1440x1080i 25
This sequence consists of:
HDV50i (EX-1) + ProRes 576@50i (DV from FX-1 captured via BM component)
Externally captured audio
Theoritically, these two should be compatible with each other.
So far, i've synced the clips to the audio and in real-time, the sequence plays fine ( i assume FCP has automatically confirmed the footage to the 25 fps timebase). However, once i render, the rendered timeline plays the video out of sync (double speed) to the footage. I've tried copying the entire sequence to a new sequence with a 50 fps timebase and the same occurs.
Any ideas?
David Cheok is offline   Reply With Quote
Old February 8th, 2009, 06:06 PM   #2
What codec is the sequence? Are you using a preset like ProRes1080?
William Hohauser is offline   Reply
