apple pro res at DVinfo.net
Final Cut Suite
Old March 4th, 2009, 03:25 AM   #1
apple pro res
I'm running a wedding business and doing everything apple pro res 422
The thing is the amount of space this codec takes up
If anyone else is using this codec how much disk space do you have to use this codec without filling up your hard drive every time you log your footage
Luke
Luke Oliver is offline   Reply With Quote
Old March 4th, 2009, 10:07 AM   #2
I just transferred 2 hours of AVCHD footage to ProRes422 yesterday. I started with 7GB from the camera and ended up with 88GB worth of Quicktime files after transfer. I was using the ProRes422 HQ codec which might have increased the size even more.
John C. Plunkett is offline   Reply With Quote
Old March 4th, 2009, 10:36 AM   #3
I shoot 720P60 HDV and capture as ProRes422 720P60 and I'm using right about 1GB per minute. I guess I've been at this long enough that the price per minute of captured footage still seems low in ProRes given the cost of drives these days.
When I started, I had 9GB SCSI 2 drives that I paid $800 dollars each for and they held about 36 - 40 minutes of DV footage for a cost of $20 per minute. Keep in mind, this is back when 60 minute Sony DV tapes were $20 each...
Old March 4th, 2009, 11:19 AM   #4
Unless you are doing heavy colour correction or effects, you are pretty much wasting disk space with the HQ version. If you are just doing basic cuts and using a few filters here and there, then you should be just fine using the "regular" ProRes 422.
Mike Barber
"I'm laughing to stop myself from screaming."
Mike Barber is offline   Reply With Quote
Old March 4th, 2009, 11:20 AM   #5
Check out http://images.apple.com/finalcutstud..._ProRes_WP.pdf
Mike Barber
Old March 4th, 2009, 11:29 AM   #6
What would you define as "heavy".
Old March 4th, 2009, 11:37 AM   #7
Good question. I would characterize heavy by the amount you are trying to push or pull. if you are just tweaking the levels or temperature, that's pretty light. If you are doing "real grading" which dramatically change the picture, then you would likely be getting into heavier territory. That's a simplistic way to put it.
Mike Barber
