G5 1.6 ghz can't boot off DiskWarrior 3... at DVinfo.net
Final Cut Suite
Old September 30th, 2003, 04:26 PM   #1
MPS Digital Studios
I tried booting off my CD copy of DiskWarrior 3 on my G5 1.6 ghz, but couldn't. I've emailed Alsoft, but we all know that will take a day or two.
Any solutions out there?
heath
My Final Cut Pro X blog
Old September 30th, 2003, 11:30 PM   #2
Retired DV Info Net Almunus
What actually happens when you hold that 'C' key down during the restart, Heath? Does the G5 just ignore it?
Old September 30th, 2003, 11:32 PM   #3
MPS Digital Studios
<<<-- Originally posted by Ken Tanaka : What actually happens when you hold that 'C' key down during the restart, Heath? Does the G5 just ignore it? -->>>
It stalls out with a folder/question mark.
heath
Old September 30th, 2003, 11:49 PM   #4
Try holding the Option key down during restart instead of the C key. This should present a selection of drives, including the DW CD, from which you can instruct the Mac to boot.
Old September 30th, 2003, 11:56 PM   #5
MPS Digital Studios
<<<-- Originally posted by Ken Tanaka : Try holding the Option key down during restart instead of the C key. This should present a selection of drives, including the DW CD, from which you can instruct the Mac to boot. -->>>
I'll give it a shot when this girl returns the CD to me on Friday.
heath
Old October 1st, 2003, 12:04 AM   #6
Warden
The G5 needs OS 10.2.7 or newer. The DiskWarrior disk is probably 10.2.5. Alsoft should have an update or patch available.
Jeff Donald
Carpe Diem
Old October 1st, 2003, 12:12 AM   #7
MPS Digital Studios
<<<-- Originally posted by Jeff Donald : The G5 needs OS 10.2.7 or newer. The DiskWarrior disk is probably 10.2.5. Alsoft should have an update or patch available. -->>>
Okay, so I'll download this patch(es) and it will indicate to the G5 to boot off the Disk Warrior disk, right?
heath
Old October 1st, 2003, 06:45 AM   #8
Warden
They may need to supply a new boot CD. It could also be a patch, that enables the OS to boot off an older version of the OS. Alsoft will have the answers.
Jeff Donald
Carpe Diem
Old October 1st, 2003, 02:13 PM   #9
MPS Digital Studios
Alsoft official word
From alsoft tech support (but it doesn't indicate if owners of Disk Warrior 3 are eligible for a free disk or how it works to get a copy):
"The current DiskWarrior CD will not start the new computers released by Apple.
When Apple releases new machines we normally have to release new CDs that will start these machines.
We are working closely with Apple to provide a compatible CD and hope to have it soon.
Once this CD is release we will make note of it on our web site.
While the DiskWarrior CD will not start the new machines the DiskWarrior application is perfectly safe and will rebuild the directory of the disk without a problem.
For the time being to run DiskWarrior on your new machine you will need to start the computer in Target Disk Mode, start the computer while holding the "T" key, connect it to another Mac with a FireWire port, and run DiskWarrior v3.0 from the other Mac."
heath
ps-I have a PowerBook, but how many others actually HAVE a second Mac?
Old October 1st, 2003, 04:01 PM   #10
Warden
Any Mac (or external HD for that matter) with FireWire and an OS system file can boot your computer in target mode. Any friends with a current G4 Mac?
Jeff Donald
Carpe Diem
Old October 1st, 2003, 04:10 PM   #11
MPS Digital Studios
How do you put an OS system file into an external hard drive? Just install Jaguar, like normal?
heath
Old October 1st, 2003, 04:39 PM   #12
MPS Digital Studios
Got another email from Alsoft about replacing Disk Warrior 3 CDs with new discs.
"This CD will be a replacement CD for current DiskWarrior owners. We normally charge $12.95 plus shipping for replacement CDs."
More money...
heath
Old October 1st, 2003, 08:32 PM   #13
Warden
Yes, install Jaguar onto the FireWire Drive. Go to system preferences>startup disk and select the FireWire Drive as the startup disk. It may also produce the same flashing icon, not sure. If it does flash, Target Disk mode is the only way to use your existing disk.
Jeff Donald
Carpe Diem
