MacBook Pro Prores HQ playback at DVinfo.net
Final Cut Suite
Old May 25th, 2009, 08:00 AM   #1
Have just on-lined high def project in Pro-res HQ. I am monitoring through AJA IoHD and find the picture playback is stuttering on my panasonic 17" monitor . Media is on a G-Tech Raid E-Sata drive. The MacBook Pro is a 2.5 2 core with 4 gb ram.
Any ideas? or do I have to get a MacPro? if so what spec?
Bruce Rawlings is offline   Reply With Quote
Old May 25th, 2009, 08:09 AM   #2
Are the render files on the external drive as well?
Old May 25th, 2009, 11:56 AM   #3
Check and see if Playback Quality in FCP is set to Dynamic.
Pro-Res is selectable and test lower settings to determine bottleneck.
-C
Old May 26th, 2009, 01:33 AM   #4
I am new to FCP. Should render files be on a separate drive?
Old May 26th, 2009, 07:01 AM   #5
Yes. I suggest that you read the installation manual.
Old May 26th, 2009, 04:34 PM   #6
I've never had an issue with render files being on the same drive as my media (although back in the early days (FCP1.0.2/1.2.5 on a B&W g3 450MHz) I kept my media, application AND render drives all separate) but neither render or media files should ever share the system or application drive.
Old May 26th, 2009, 05:07 PM   #7
Better than Halle Berry
I'd render the whole thing to one ProRes HQ self-contained file and play it off the ESATA. When ProRes HQ stutters it's almost always because the data rate exceeds the capabilities of the hard drive.
Noah
Noah Kadner is offline   Reply With Quote
Old May 30th, 2009, 01:37 PM   #8
Have you chosen the appropriate Video Output setting? Make sure if you're editing 29.97, it's set to 29.97, etc....
Sony EX3, Canon 5D MkII, Chrosziel Matte Box, Sachtler tripod, Steadicam Flyer, Mac Pro, Apple/Adobe software - 20 years as a local videographer/editor
Mitchell Lewis is offline   Reply
