Mixing SD and HDV at DVinfo.net
Final Cut Suite
Old May 26th, 2009, 08:23 AM   #1
Mixing SD and HDV
Hi.
Still trying to learn FCP 6.
I have anomorphic SD and HDV 1080i60 clips and put them together in a sequence ultimately to go to a DVD.
When I put the clips on the timeline, I thought that FCP 6 would automatically "convert" the HDV to the sequence setting. I did render the sequence, but when I check the "format" in the item properties it still says that the HDV clips are HDV. How to I convert to SD?
Thanks in advance for any help.
Brian
Brian Maynard is offline   Reply With Quote
Old May 26th, 2009, 10:45 AM   #2
You are seeing the properties of the original clips. FCP does not touch the original files for good reason. The rendered SD files are kept in a different folder called "Render Files".
Old May 26th, 2009, 01:57 PM   #3
Ahhhh, thank you for your help, William.
Brian
