Installing FCS2 at DVinfo.net
Final Cut Suite
Old June 22nd, 2009, 04:27 PM   #1
Installing FCS2
So I'm installing FCS2 on my iMac and I happen to notice during the second disk it says: Approximate time remaining: 19 hrs 52 minutes. Cowabunga! So I called Apple Support: "Yep, that sounds about right," he says. "Or you could custom install the audio files to an eternal HDD. But that'll take a little longer."
This better be worth it.
Charles Newcomb is offline   Reply With Quote
Old June 22nd, 2009, 04:38 PM   #2
My install of FCS2 was in the neighbourhood of 3 - 4 hours on a white iMac 2.16GHz.
If memory serves, there is a known bug with Time Remaining for Install.
Old June 22nd, 2009, 04:43 PM   #3
I had the same thing when i installed it. Mine took about 2 - 3 hours on a MacPro
Ryan Hansen is offline   Reply With Quote
Old June 22nd, 2009, 07:46 PM   #4
It's at 46% of audio disk 3 right now, and says 13 hours and 20 minutes left.
24" iMac, 2.8 ghz, 4gig ram
Old June 23rd, 2009, 03:02 AM   #5
Yup that is about right for all the content and templates they are all zipped up and take forever to extract.
If you just want the programs only it is only about 30 mins, thats what I did to start and then added the content and templates as and when I needed it.
Old June 23rd, 2009, 08:37 AM   #6
Well, it's done... five and a half hours. But that's better than the 19 hours it said it would take, initially. Apple said I could load it on my new MacBook Pro, too. I'm not sure I'll live that long, however.
This has been quite the experience, moving over from the PC side. Looks like I'm going to have to take some room away from the Windows partition on my iMac, because FCS took 53 gigs.
Now on to learning how to use it all.
Old June 23rd, 2009, 09:01 AM   #7
Hi Charles and glad it went on OK.
what I have done is just installed the programs on my macbook pro as the content takes up a lot of space.
I also installed the programs only on my i-mac hard drive and then put all the content on my edit drive a 1tb g-tech g2.
That way I can use the programs on the i-mac with the content from the g-tech hooked up or if I need to anything with the macbook I can hook the g-tech up to that too.
Old June 25th, 2009, 01:55 AM   #8
Yeah, install takes a long time, especially for the Content discs, in which the data is zipped and has to be unzipped during the install process. I was installing on a 3.06 Ghz iMac with initial indications of around 13 hours to install. It was nearing completion right around the 3 hour mark, and then failed with a disc error. I tried it again from the start and noted failure at the same point.....long day. I tested the disc and the remaining ones and noted physical pits in two of them, the likely cause of the error. The other one completely failed I/O tests.
I couldn't just switch out the bad discs. Apple wanted to replace the entire package, but since it had been shipped to me, I had to ship it back. But they overnighted me a replacement package. (at 17 pounds of books in the box, that shipping is not cheap.)
But I also figured that aside from just having to unzip the data during install, it is also sourcing from the optical DVD drive - which likely adds to length of time it takes to install. So this time, I decided to make a disc image of all the discs first, and then install from the images. Sure, it took a while to make the disc images, and I didn't pay attention to exactly how long, but it felt faster. When I was done, I mounted all of them onto the desktop at the same time, and installed from them. Sourcing the zipped files from the imaged files on the hard drive was faster than the DVD install, and since they were all mounted at the same time, I didn't have to deal with the disc-change prompts.
I had to delete the image files after install, though. They took up a huge amount of space and weren't needed anymore. But I think installing from them was a more efficient way to go - which was really a benefit after having slogged through the two previous failed installs.
-Jon
"Are we to go on record, sir, with our assertion that the 'pink hearts, yellow moons, orange stars, and green clovers' are, in point of fact', magically delicious?"
- Walter Hollarhan before the House Subcommittee on Integrity in Advertising - May, 1974
Jonathan Jones is offline   Reply With Quote
Old June 25th, 2009, 12:23 PM   #9
Thanks again for all the helpful hints. Everything seems to be working fine.
A related question: When I set the computer up initially it was going to be a Windows editing machine, so I put the bulk of the storage capacity of the external drive on the Windows side (I did it the other way around on the operating drive). Is there a way to reassign allotted space on the external drive (1 TB Western Digital) without having to reformat it? Thanks again.
Old June 26th, 2009, 08:19 AM   #10
Just installing FCS2 today on iMac 2,8G IC2Duo 4GRam.
The deal starts at 11:00 this morning.
Running throughout Live Type Media disc 1A 55% complete.
System noticed 3 h 15 m remaining.
2 Discs remaining.
Time now here 16:18 h.
GMT+1
Juan Todoli is offline   Reply With Quote
Old June 26th, 2009, 10:37 AM   #11
Finish!
18:30 in the evening.
+/- withrawing promt disc changes 30 minutes...
11h to 18h = 7 hours.
Hope this experience "live" help too, Charles.
Cheers.
Old June 26th, 2009, 07:42 PM   #12
Originally Posted by Juan Todoli View Post
Finish!
Cheers.
Well, I'm glad I'm not the only one. Same computer here, Juan.
