-   Final Cut Suite (https://www.dvinfo.net/forum/final-cut-suite/)
-   -   Monitoring Video With iMac? (https://www.dvinfo.net/forum/final-cut-suite/238626-monitoring-video-imac.html)
Seth Mondragon July 7th, 2009 09:59 PM
I'm currently editing on a PC with Premiere Pro 1.5 and I have a little TV next to my computer. Can I do this using an iMac with Premiere Pro CS4?
-seth
Scott Anderson July 8th, 2009 09:51 AM
Yes, you should be able to send your video over Firewire, through a deck/camera/Firewire converter that has analog outputs, to your TV.
Adobe Premiere Pro CS4 * Set up a device for device control
Seth Mondragon July 8th, 2009 10:46 AM
I currently have a Sony DSR-11 deck and that's what I've been using...I just wasn't sure if that would affect the 16x9 footage I would be editing. I would plan on having my monitor to be an LCD widescreen TV...would the aspect ration on the monitor be correct?
-seth
Scott Anderson July 8th, 2009 02:03 PM
Originally Posted by Seth Mondragon (Post 1168836)
would the aspect ratio on the monitor be correct?
Yes, if your TV has the ability to stretch a 4x3 signal out to fit the 16x9 screen. DV and DVCam footage shot in widescreen actually records to tape as standard 720x480 at a 4x3 aspect ratio NTSC. Look at the footage on a 4x3 monitor, everyone looks tall and skinny. Look at it on a 16x9 monitor with a "Stretch" mode, and it looks perfect.
The (discontinued) DSR-11 did not inherently deal with widescreen footage, so there's no letterbox output for 4x3 monitors or similar controls. But, like I said, your LCD monitor probably has a setting that will work.
