clip browser vs XDCAM Transfer at DVinfo.net
Final Cut Suite
Old July 12th, 2009, 08:19 PM   #1
I just want to be perfectly clear about this. When bringing clips into FCP from EX3 - do I have anything whatsoever to do with clip browser? i,e, do I use XDCAM Transfer only and simply forget about clip browser?
tamerlane57
Allen Minor is offline   Reply With Quote
Old July 14th, 2009, 04:04 PM   #2
If you only plan on using the media in FCP then the answer is yes, you only need to use XDCAM transfer.
If you want to copy the original files with the folder structure intact then it is useful to use Clip Browser. It is safer than just using finder to copy/paste files. The software has CRC checking to make sure the data copied is bit-for-bit accurate.
Devin Termini is offline   Reply
