Capturing NDF timecode at DVinfo.net
Final Cut Suite
Old July 17th, 2009, 11:41 AM   #1
On final cut pro,
How should I go about capturing footage from a tape that changes in timecord from drop frame to non drop frame?
capture now?
Katie Maguire is offline   Reply With Quote
Old July 17th, 2009, 01:26 PM   #2
Capture up to about a second before the time code changes. Resume capturing about 5 seconds after the time code change. If you need the footage right around the time code change area, you might need to change Device Control to non-controllable device and run the tape manually while you capture.
Old July 19th, 2009, 11:54 AM   #3
I'm going to need the footage around the timecode change. On FCP, how do you change capture settings to non-controllable device?
