Capturing both audio channels in FCP 4 at DVinfo.net
Final Cut Suite
Old August 7th, 2004, 11:50 PM   #1
Working on a project in FCP 4 on a different computer than when I started it. Today was the first time I captured video to the new computer. I batch captured 30 clips and the audio came in I believe as stereo (it only takes one audio track in the timeline). All of the other clips I captured on the previous computer came in with both channels of audio. I'm capturing from the same tape, so I know it has both channels.
What can I do to get both audio channels on the 30 clips. I'm sure I did something wrong on the batch capture but I don't know how to correct it. What settings should I have to capture both channels of audio? In essence, I'd like to know how to recapture these clips without having to redo it again manually.
Matt Elias is offline   Reply With Quote
Old August 8th, 2004, 12:38 AM   #2
I played around with capturing. When I used the "capture clip" feature I was able to capture both audio channels, but when I captured the same clip in a batch capture it came in as only one audio track (mono mix I believe).
Is there a separate preference for audio when doing batch capture?
Old August 8th, 2004, 11:57 AM   #3
See if this works ... In the Log & Capture window. Select the Clip Settings tab and set the Audio Format to Ch1+Ch2. You'll still have to recapture but you still have the Logs (right?).
Tim Lane is offline   Reply With Quote
Old August 9th, 2004, 12:28 PM   #4
I still have the logs - but how do I tell the log and capture that I want to recapture those specific logs, clips?
Old August 9th, 2004, 02:03 PM   #5
If you delete (or move) the captured QT files from your scratch disk. The "logged items" in your FCP Logging Bin won't be able to locate them and you can re-capture from the Log and Capture window. Let me know how it goes.
Old August 9th, 2004, 10:02 PM   #6
Will I be able to preserve the in and out points that I logged? I'd like to find a way to avoid having to go in and reset each in and out point of 30 clips.
Old August 9th, 2004, 11:29 PM   #7
Yes. The In/Outs are logged in the logging bin -- you don't delete them -- currently they are pointers to your existing captured clips. If you move the captured clips (the old ones) to another folder then the items in the logging bin will display as offline. Then you can batch capture new clips with your new settings.
Old August 10th, 2004, 03:17 PM   #8
DVCreators.Net
Tim has the right idea!
Try this:
1. In the Browser, select the clips you want to re-capture.
2. Control-click on one and choose "Make Offline"
3. Choose to delete the Media
4. Go File > Log and Capture
5. Click on the Clip Settings Tab
6. Change the Audio pop-up to Stereo (instead of A1+A2 or Mono Mix)
7. Click Batch Capture in the Lower Right
8. Uncheck "Use Logged Clip Settings" (this will use the Settings that you just set to Stereo"
This is from the top of my head, so if you have any problems with any step, post and I'll hook up a deck to walk through it.
Guy Cochran
Old August 10th, 2004, 07:11 PM   #9
Thanks so much for your advice guys. Right now I'm not able to use the G5 (my brother uses it for work) so I can't test this out. My G4 is still acting goofy w/ audio out of sync. I'm taking it to the Apple Store on thurs to get it back in working order (crossing fingers).
I had posted previously that my project works fine on the G5, but on the G4 the audio is out of sync in the viewer, timeline, and canvas. The G4 was taken to a local mac store that is an authorized apple serice center and they could not remidy the problem. Thus, my last option is the Applestore - which is an hour drive for me.
By the way, I spoke w/ the Pro Video guys from AppleCare, and found out that they charge $200 for their services! That is $200 everytime you call, or $800/year. They couldn't give much advice until I forked over the 200 - hopefully you guys here in the forum don't charge as much : )
Old August 10th, 2004, 07:37 PM   #10
DVCreators.Net
Hey we're much cheaper here! But a couple things before going too nuts.
Which mic did use to capture the audio?
I'm guessing the on camera stereo mic?
If you had used a shotgun mic or lavalier which is a mono mic, you would choose A1+A2 or mono mix.
What did you have the camera's audio setting at 16bit or 12bit?
You should always have it set to 16bit (unless capturing 4 channels on a Canon XL_)
16 Bit = 48kHz
12 Bit = 32kHz
A default Final Cut Pro Sequence is 48kHz. If you capture 12 bit sound w/ a 48kHz preset, you're going to have sync issues.
Guy Cochran
Old August 11th, 2004, 03:57 PM   #11
On this particular tape I had two Sennheiser eW500 lavs connected to a Studio 1 XLR adapter. At the time I shot this footage (last summer) I was just starting out w/ my GL 2 and cannot remember if it was shot in 12 or 16 bit. I hadn't changed any of the settings, so I'm sure it was set at the default.
The funny thing is, is that I ran a batch capture w/ this tape a few weeks ago on my G4 (before it was giving me problems) and it captured two channels of audio - so I know that there are two channels there.
Old August 17th, 2004, 09:05 PM   #12
Guy, I was able to use my G4 today (seems to be working OK) and go through the steps that you listed. After the batch, the clips still came in w/ only one track of audio.
In the Log and Capture, I captured one of these clips using the "Cature Clip" function and it came in w/ both tracks of audio. When I batch capture this same clip w/ others they all come in w/ only one track.
I guess my next option is to capture them all individually?
Old August 17th, 2004, 09:26 PM   #13
DVCreators.Net
In the Browser, make the clips offline w/ a control-click.
Then select all the clips and find the "Track Column" in the Browser - make sure it says "1V + 2A" if it doesn't control-click to change.
Locate the "Audio Column" in the Browser control-click and change to A1+A2.
Now go File>Batch Capture.
You'll want to "Use Logged Clipped Settings" for your Capture.
Good luck,
Guy Cochran
Old August 17th, 2004, 09:31 PM   #14
Thanks Guy.
Well, a minute after I logged that last clip individually, the audio came out of sync. I haven't done the batch yet as you suggested - I'm hesistant to do this if the audio is not working properly. I think I will take it to the Apple Store this weekend...
And people wonder how aneurysms develop.
Old August 17th, 2004, 11:48 PM   #15
I want to note that the audio didn't come out of sync in that individual clip only, every clip in the entire project is out of sync. The way I wrote it above may have sounded like only that clip was out of sync.
I'm confused on how the audio in my project can seemingly work fine and then all of a sudden go out of sync. I would think that it would be one way or the other, always.
