globe at the beginning of start up at DVinfo.net
Final Cut Suite
Old September 24th, 2004, 06:26 PM   #1
I dont know if my editing software had anything to do with since I just installed OSX as well as FCP 4, but when I start the comp up I get a grey screen with a blinking globe it sits up there for 5-10 minutes before the operating system gets going...whats up?
Ryan Wachter is offline   Reply With Quote
Old September 24th, 2004, 06:31 PM   #2
Warden
Go to in OS X go to System Preferences (under Apple in upper left corner)>Startup Disk> click on the folder that contains your system files and restart your computer. It should startup like normal now. what version of OS X are you using?
Jeff Donald
Carpe Diem
Old September 24th, 2004, 11:40 PM   #3
That did work thanks! Im using panther 10.3....so what exactly did I do there that fixed (what exactly was wrong with it)?
Thanks again Jeff.
Old September 25th, 2004, 05:09 AM   #4
Warden
Your computer didn't have a startup folder (folder that contains a working OS) selected and was waiting for you to select a folder. After a specified period of time, it times out and selects a folder to startup from. In Applications>Utilities>Disk Utility> run repair permissions, after installing a new OS. Are you connected to the internet on that computer?
Jeff Donald
Carpe Diem
Old September 25th, 2004, 07:32 PM   #5
Yes I am writing to you on the comp that had the problem.
Old September 25th, 2004, 07:55 PM   #6
Warden
Do a software update, Apple Menu>Software Update>Update Menu>Download only. After downloading all the updates and installing them (just keep installing, you don't have to restart after each install) restart the computer and then repair the permissions. Always repair permissions after installing any software or update.
If you're using FCP you may not want to update to 10.3.5. You may want to leave QuickTime alone as well. Post back if yo have questions.
Jeff Donald
Carpe Diem
Old September 26th, 2004, 02:46 PM   #7
<<<-- Originally posted by Jeff Donald : Do a software update, Apple Menu>Software Update>Update Menu>Download only. After downloading all the updates and installing them (just keep installing, you don't have to restart after each install) restart the computer and then repair the permissions. Always repair permissions after installing any software or update.
If you're using FCP you may not want to update to 10.3.5. You may want to leave QuickTime alone as well. Post back if yo have questions. -->>>
Whats the deal with FCP and 10.3.5? I have a G4 with FCP HD and 10.3.5 and I can't capture properly. If I don't upgrade to HD, it captures fine. Does this have anything to do with 10.3.5? If so, what version of OSX should I be running? Thanks.
Paul Chun is offline   Reply With Quote
Old September 26th, 2004, 08:17 PM   #8
I read your post just minutes too late. The mac sent the upgrades for the week. I went to HD and now it wont start up. It just goes to the fcp has unexpectedly shut down...is there anyway to fix it or revert it or am I going to have to reinstall it?
Old September 27th, 2004, 07:18 PM   #9
Warden
sorry to respond so late, I've been without electricity, curtsey of hurricane Jeanne. Read this thread, if you have questions, post back.
Jeff Donald
Carpe Diem
