Can we export sequence to Adobe Photoshop CS2? at DVinfo.net
Final Cut Suite
Old June 10th, 2005, 01:31 PM   #1
I have sequence in FCP5 however if i want to change a characters eyes to green or blue, Is there a way in FCP5 to do it? or is there a way to export the footage in Adobe Photoshop CS2 and edit frame by frame.
Any ideas?
Harikrishnan Ponnurangam is offline   Reply With Quote
Old June 10th, 2005, 01:44 PM   #2
Although I have never exported frame by frame to Photoshop, I believe the first step would be to deinterlace your footage. Once that is done, you could export the section you need to edit to a standard DV file, open in QT player then cut and paste frame by frame into photoshop. Im sure there is an easier way, but this would surely work.
That having been said, I wouldnt waste the time to do simple color changes in Photoshop. You'd be amazed at what you can pull of with Apple's 3-Way Color Corrector. Check out this tut-
http://creativemac.com/articles/view...e.jsp?id=29317
Patrick Pike is offline   Reply With Quote
Old June 10th, 2005, 02:08 PM   #3
Great article exactly what i need
Pat,
You simplified my work. Thanks for the link. Appreciated!!! Creativemac.com has very good articles i don't know how i missed this article.
Hari
