FCP 5 > Render & Export to QT Movie Looks Bad - Page 2 at DVinfo.net
Final Cut Suite
Old June 27th, 2005, 09:29 PM   #16
What I've Tried
I have gone back to using the original media files from the PC (not the ones converted by compressor). I just ignore the "media not optimized message." Before rendering, everything looks great. When I edit a clip into the timeline from the browser or viewer... it only has the grey bar over it... I believe the label is "media" when the mouse cursor is left over it. When I apply speed changes, the bar stays gray. When I enable frame blending, the bar turns green and the label is "Preview." If I enable motion blur for the clip, then the bar turns orange. The areas with orange bars render, and look fine. Areas with green preview bars, just don't look right when rendered, and the other areas don't need to be rendered?
I'll check for difference between clip and sequence properties when I get back to my studio in the morning. I havn't tried recapturing. It would be an 8+ hour project, and I want to avoid it if at all possible. Maybe I'll have to try a small segment though... Thanks for the help everyone.
Matt Trubac
TruVision Studios
Phone: (517) 282-2915
http://www.TruVisionStudios.com
Matt@TruVisionStudios.com
Matt Trubac is offline   Reply With Quote
Old June 27th, 2005, 10:33 PM   #17
Frame blending enabled gives smoother results in my experience since it creates "tween" frames rather than duplicating frames to fill the slo mo time.
Dave Perry Cinematographer LLC
Director of Photography • Editor • Digital Film Production • 540.915.2752 • daveperry.net
Dave Perry is offline   Reply
