-   Final Cut Suite (https://www.dvinfo.net/forum/final-cut-suite/)
-   -   FCP 4.5 combining sequences with disolves: Problem (https://www.dvinfo.net/forum/final-cut-suite/46653-fcp-4-5-combining-sequences-disolves-problem.html)
Cleveland Brown June 22nd, 2005 11:09 PM
I have built several sequences and now want to combine them on one timeline. The problem I am having is when I tell it to disolve from one sequence to the next, like you would from one shot to the next, it puts the transition in on either the last clip of one sequence or the first of the next sequence. Also I can't make the duration longer than one frame. What am I missing here? All I want to do is a 2 second disolve (audio and video) between multiple sequences in a (Master timeline).
Todd Mizomi June 22nd, 2005 11:43 PM
It sounds like you don't have enough room at the ends of your sequences. In your timeline, cut off about 30 frames from the ends of the two clips you are trying to dissolve between, move the clips together and set the dissolve.
You may need to go back to the original sequences to make them longer to give yourself more room to make the dissolves.
Hope this helps
C. Byrne June 23rd, 2005 03:13 PM
Have you tried opening the transition up in the viewer and editing it there?
Shane Ross June 23rd, 2005 04:01 PM
You need "Handles." If you bump one clip up against the other, they have no overlap, and therefore cannot dissolve. If you want a 2 second dissolve, you are going to have to overlap the sequences by 2 seconds.
