Multiclip Sequence at DVinfo.net
Final Cut Suite
Old November 2nd, 2009, 01:15 PM   #1
Multiclip Sequence
I just finished working on a shoot that used two EX-1s that used TOD for the timecode. We set them simultaneously, but I guess we screwed up somehow and they're a second off. There are about a hundred clips I need to have multiclipped, and I know there's got to be a faster way than doing them individually.
Now, I feel I've come close using a quasi-Avid assistant editing technique. I selected all the clips and multiclipped using starting timecode. Fantastic - all of Camera A is on track 1 and all of Camera B is on track 2. Camera B was a second behind, so I just cut one second at the head of Camera B and now everything is in sync. What I'd do next, but I have no clue how, is I want to assign auxiliary timecode to all the clips in the sequence. Then, I'd go through and multiclip them by aux TC and I'd be good to go.
Now, I know how to change the aux TC of one clip, but is there a way to have a ripple effect or change them all? To do them one by one would defeat the purpose of doing it this way. Or am I going about this all wrong and is there a better way?
Bradford Holt is offline   Reply With Quote
Old November 2nd, 2009, 01:25 PM   #2
Take a look at something called SequenceLiner.
It's used to sync TOD audio with video, but perhaps it might be able to sync two video clips,too.
If so, then it should create a sequence of clips with video on tracks 1 & 2. If they're all off by a consistent amount, you can grab all the clips in one track and slip them accordingly.
Dean Sensui
Old November 13th, 2009, 09:20 AM   #3
Unless I'm not properly understanding the problem, pluraleyes might be a good choice as well - it's original intent is for syncing multiple camera footage based on audio matches between the two and it's quite impressive. It also creates multicam clips automatically as well. Free demo / trial available.
Ryan Mitchell is offline   Reply
