Just starting Final Cut 5. Need some quick help. at DVinfo.net
Final Cut Suite
Old June 27th, 2005, 10:45 PM   #1
Hello guys I thought I setup everythnig correctly and started to capture with my Z1u and everything seemed fine but when I went to play the video in the timecode I found it was unrendered. How do I capture so when I start to edit the raw footage it does not need to be rendered from the start?
Kyle Fasanella is offline   Reply With Quote
Old June 28th, 2005, 12:42 AM   #2
Before you creat a project, go to the Final Cut Pro menu, in the "Easy Setup", choose HDV-180i60. Then create a blank project. That will correctly setup the capturing and timeline for HDV environment.
Kaku Ito is offline   Reply With Quote
Old June 28th, 2005, 01:16 AM   #3
Thats exactly what I did and when I bring the capture footage into the timeline there is a red bar above it.
NM I have it !
