Dual-Core 3.33GHz vs. Quad-Core 2.8GHz? at DVinfo.net
Final Cut Suite
Old March 19th, 2010, 01:34 PM   #1
Hello. I'm looking at a new iMac for video editing with FCP.
I'm curious as to the advantage of a quad-core processor, when its speed is not as fast as a dual-core.
Can anyone help me out?
Thanks.
Devin Vaughn is offline   Reply With Quote
Old March 19th, 2010, 01:53 PM   #2
While it doesn't come out in real performance like this, a dual 3.33 equals 6.66 and a quad 2.8 equals 11.2. No matter what, this quad processor will give you better performance.
Old March 19th, 2010, 01:57 PM   #3
Which of course is further complicated by the fact that not all applications can lever the performance advantages of multiple processors but generally speaking, more processors = good.
Old March 21st, 2010, 08:29 PM   #4
perhaps not all apps, but specifically FCP?
Independent Filmmaker in Canada's Capital
Graeme Hay is offline   Reply With Quote
Old March 21st, 2010, 08:33 PM   #5
I believe that FCP 6 is a single-core application, which means that if you are using FCP and have no plans to upgrade, go with the 3.33GHz dual-core. If you're using FCP 7, which I believe is multi-core, go with the quad-core.
Equip: Panny GH1, Canon HG20, Juicedlink, AT897, Sennh. EW/GW100, Zoom H2, Vegas 8.1
Brian Boyko is offline   Reply With Quote
Old March 21st, 2010, 09:16 PM   #6
FCP will recognize a quad-core chip and utilize all cores during renders. FCP can not recognize two multiple core processors, such as in 8-core MacPros, but Compressor can when the system is set up correctly.
William Hohauser is offline   Reply
