Import Final Cut XML to FileMaker at DVinfo.net
Final Cut Suite
Old April 24th, 2010, 06:38 AM   #1
I'm trying to import a Final Cut XML file into FileMaker Pro. I'm trying to get a shot database going for a documentary, and I wanted a starting point with clip names, duration, and already inputed descriptions so I could add on to that. I know there's also a way to import frames for each clip.
I know you need to assign an XSL file when importing the XML, so it knows what to do with the data.
Does anyone have any sample XSL files to use, or know where to get them? Tutorials?
Thanks for any help you may have!
Joey Daoud is offline   Reply With Quote
Old April 24th, 2010, 04:31 PM   #2
I'm not sure, but if you don't mind using a third party solution, either CatDV as a standalone solution or something like Sequence Clip Reporter (that exports sequences directly to excel spreadsheets) might be good intermediate steps.
www.afterglow.co.nz
Craig Parkes is offline   Reply
