FCP5 Render after capture?? at DVinfo.net
Final Cut Suite
Old July 17th, 2005, 12:10 PM   #1
Hey guys. I'm using fcp5 with an fx1 to capture 1080i footage. after i capture the footage, i can view it in the viewer, but if i try to drag it to a timeline, it requires a render. is this unavoidable? its a ridiculous amount of render time that im having to go through. does everyone have to render before they can edit hdv in fcp5? is there a resource for UP TO DATE workflow information? i searched all through this forum for an answer to my initial question, and i hope im not repeating something already answered.
im feeling like it shouldnt be this way. theres got to be something wrong with my settings. help please!
heath
Heath Hays
MGD Productions
Heath Hays is offline   Reply With Quote
Old July 17th, 2005, 12:16 PM   #2
I can't offer any direct solutions since I haven't used FCP 5 yet. However, with every other version of FCP the conditions you describe occur when the clip settings don't agree with the sequence settings. Look very closely at your clip and sequence properties and see if anything is different. If so then change the sequence settings to match those of the clips.
Old July 17th, 2005, 06:03 PM   #3
Your sequence settings should be:
Frame Size: HD (1440X1080) (16:9)
Pixed Aspect Ratio: HD(1440X1080) - Do NOT check anamorphic box
Field Dominance: Upper (Odd)
Compressor: HDV 1080i60
Audio Settings: 48Khz 16-bit, Config-default
Bryan Suthard is offline   Reply With Quote
Old July 17th, 2005, 10:00 PM   #4
got it. thanks guys. i have a new question, but see my new post if you've got time to help.
heath
Heath Hays
MGD Productions
