Your Blu-Ray Solution Export from Final Cut at DVinfo.net
Final Cut Suite
Old September 1st, 2010, 03:24 PM   #1
I've given up on using Compressor for now to create my Mpeg-2 Elementary Stream files. I've discovered Encore and will be using it for now. It's really easy to use and blu-ray is amazing. Anyways, how would you convert a file for Encore (Blu-ray) w/o using Compressor or Premiere? Can Mpeg Steamclip do this or another simple program to convert my QT files to Mpeg 2 Elementary Stream?
Thanks.
Kelly Langerak is offline   Reply With Quote
Old September 1st, 2010, 04:20 PM   #2
Encore will convert Quicktime into h.264 or MPEG2 HD files. You can also tell Compressor to not burn a BluRay disc but just make the files. This is in the job action tab.
Old September 2nd, 2010, 03:47 AM   #3
I use compressor to make the mpeg2 or h264 streams ready for blu-ray then import tat in to Encore. I've found that letting Encore handle the transcoding makes a mess of things from time to time and you don't know if it's good or bad until you've watched the entire blu-ray disc, then have to go back and do it all over again.
Qualified UAV Pilot with CAA PFAW
Aerial Photo / Aerial Video | Corporate Video Production
Dave Partington is offline   Reply With Quote
Old September 2nd, 2010, 06:09 AM   #4
Yes, that's been my experience with Encore also. I also have had problems with BluRay discs working once or twice in a BluRay player and then stopping. It seems that some BluRay players seem to actually burn the media into failure but others don't. Which BluRay media do you use?
William Hohauser is offline   Reply
