Older version of FCP and T2i at DVinfo.net
Final Cut Suite
Old December 24th, 2010, 12:51 AM   #1
Hello,
I was wondering what the best codec is to trans-code to other than prores?
I use mpeg stream-clip
Matt Fowler is offline   Reply With Quote
Old December 24th, 2010, 10:23 AM   #2
DVCPro HD.
Arnie Schlissel is offline   Reply With Quote
Old December 24th, 2010, 03:35 PM   #3
thanks with version 5.1.4 am i going to have to render every clip that bring to the time-line?
Old December 24th, 2010, 04:23 PM   #4
Do you mean do you need to convert every clip to DVCPro HD? Yes.
Old December 24th, 2010, 04:35 PM   #5
i understand that but every time i put a transition on the clip or make an adjustment i have to render it on the time-line to view it. Is there a way around this?
Old December 25th, 2010, 04:25 PM   #6
That's because your sequence settings don't match the footage in your timeline.
This is covered in your FCP manual, BTW.
