Final Cut Pro 7 to CS5 at DVinfo.net
Final Cut Suite
Old January 1st, 2011, 06:38 PM   #1
Hi,
I would like to import my entire final cut pro project (10 bins,5 sequences, 300+ clips) to Premiere CS5. I have done this before but it has been awhile.
So I did export as XML and I can't seem to get more than 1 bin and 1 sequence to export. I checked the master clips, but still 1 bin, 1 sequence.
Help would be greatly appreciated
Joe Riggs is offline   Reply With Quote
Old January 3rd, 2011, 09:10 AM   #2
You have to make sure NOTHING is selected in your FCP Browser window. If you select a sequence, you will convert a sequence. If you select nothing, the whole project will be saved in the XML.
Jiri Fiala is offline   Reply
