Sequence Settings at DVinfo.net
Final Cut Suite
Old March 8th, 2011, 01:44 PM   #1
Sequence Settings
I'm using a Canon t2i to shoot with and then converting the raw cannon footage to ProRes 442 files in compressor to work with in FCP.
When I drop the ProRes files into the FCP timeline and hit command 0, this is the info I get for my sequence settings. Does this all look correct?
http://i591.photobucket.com/albums/s...en-capture.png
Oliver Darden is offline   Reply With Quote
Old March 9th, 2011, 02:04 AM   #2
Re: Sequence Settings
Looks fine, assuming that's what you wanted the footage to be. I'm guessing your conversion matches the frame rate of the native footage?
Just so you know what you're converting to, here's a great overview of ProRes versus ProRes HQ:
ProVideo Coalition.com: Apple | Vendor Blog
Allen White is offline   Reply With Quote
Old March 9th, 2011, 06:53 PM   #3
Looks correct to me.
Sony EX3, Canon 5D MkII, Chrosziel Matte Box, Sachtler tripod, Steadicam Flyer, Mac Pro, Apple/Adobe software - 20 years as a local videographer/editor
Mitchell Lewis is offline   Reply With Quote
Old March 10th, 2011, 11:11 PM   #4
Allen, I hope so.
I usually just right click the raw cannon file and open with compressor then I drag the ProRes 442 setting to the clip and convert it.
Old April 15th, 2011, 12:19 AM   #5
To make your life easier, download Canon's e1 plugin to batch convert your footage. Also, if you're on FCP7, ProResLT is good enough. If FCP6, normal ProRes is fine. No reason for HQ at all. It's like putting an olive in 5gal Tupperware.
There is a setting in the batch capture window to change when you install it. Canon has a simple tutorial on this. You just select ProResLT for the dslr footage is all.
David Chapman
www.davechapfilms.com
David Chapman is offline   Reply With Quote
Old April 15th, 2011, 10:20 AM   #6
Do you need Canon's plug-in AND mpeg streamclip to batch process/convert H.264 files from Canon EOS cams?
Lisa Maxwell is offline   Reply With Quote
Old April 15th, 2011, 03:16 PM   #7
No you don't.
David Chapman
