Time code at DVinfo.net
Final Cut Suite
Old May 16th, 2011, 12:59 PM   #1
Time code
I need to add a time code to a project I'm working on so when I export, it's on the video.
What's the best way to do this?
Oliver Darden is offline   Reply With Quote
Old May 16th, 2011, 09:01 PM   #2
Go Go Godzilla
Images: 15
Re: Time code
How do you mean, as a visible "time code" window where you see the timecode or as part of the final data stream on the output?
Old May 17th, 2011, 12:06 AM   #3
Re: Time code
Robert, where you visible see the time code window.
Old May 17th, 2011, 12:55 AM   #4
Re: Time code
You can add this in FCP (Effects>Video>Timecode Generator/Reader) if you want but there is also this very useful free utility to add this to any quicktime movie you have exported: Download QT Sync for Mac - Audio/video sync correction and more. MacUpdate.com
Old May 17th, 2011, 11:59 PM   #5
Re: Time code
Thanks Gary, I'll check that out!
Old May 18th, 2011, 03:45 AM   #6
Re: Time code
it's good as it creates a copy with the timecode and leaves your master clean, also seems to be very quick too and more simple than rendering a timecode burn in out of FCP.
Gary Nattrass is offline   Reply
