How to create this effect using composite modes at DVinfo.net
Final Cut Suite
Old August 12th, 2011, 10:28 AM   #1
Can anyone explain or point me to a good tutorial as how to create these freeze frame effects in Final Cut please?
Many thanks
Tim
Tim Davison is offline   Reply With Quote
Old August 12th, 2011, 01:33 PM   #2
Re: How to create this effect using composite modes
The stopped motion on the non-moving camera angles would be fairly EASY to comp, the moving cameras with require rotoscoping, which FCP DOESN'T do... After Effects it is for that.
Old August 14th, 2011, 02:06 PM   #3
Thanks Shaun. How would one go about creating the non-moving parts?
Old August 14th, 2011, 03:16 PM   #4
- Still frame captures of the frames where each of the "frozen" elements occur.
- "Cut out" the element in question in Photoshop
- Reimport the still into FCP
- Creative use of layers and opacity
Again, only works when the camera ISN'T in motion...
Old August 14th, 2011, 04:48 PM   #5
Great, many thanks Shaun. Why could the same technique not be applied when the clip is panning, for example?
Old August 15th, 2011, 01:38 PM   #6
Perspective may/will change and be readily noticeable. Give it a shot if you like, it's only time... Time spent learning to do something is time well spent.
Old August 20th, 2011, 09:25 AM   #7
Hi Tim,
It took some time for me to find back the tutorial I saw at Digital Juice a year ago but I found it here's the link;
Time After Time :: Digital Juice TV
I think this is exactly what you are looking for. For me at least is a thousand times easier then explaining it my self.
Good luck with it. And of course I'm interested to see your work when finished.
Regards,
Gerrit.
Gerrit Meijer.
Gerrit Meijer is offline   Reply
