Fixing Blemish in Interviewees Nose at DVinfo.net
Final Cut Suite
Old October 14th, 2011, 01:01 PM   #1
I have a project I'm working on where the interviewee, who is framed in a close up shot, has a noticeable booger (sorry for the gross word) in their nose and I'm worried it will be distracting for viewers. The area in their nose is very black so it really stands out.
Is there a program that I can use to fix this without having to go frame by frame? Maybe a program that I can tell to mirror the black area in their nose to the above mentioned spot? The clip is pretty long (40 seconds or so) and I cannot cover it with images or footage because of the nature of the interview; I have no choice but to show the clip in its entirety.
I even tried to use the DH_Reincarnation plugin to see if it would possibly see the "bad spot" as a dead pixel but it didn't work.....Any ideas?
Oliver Darden is offline   Reply With Quote
Old October 14th, 2011, 02:28 PM   #2
Re: Fixing Blemish in Interviewees Nose
This sort of fix requires tracking to fix, in FCS that means you'd have to use Motion. what you'd do is grab a section of the other nostril, mirror it, feather the edge to help it blend, then track it to the shot so that it moves as the interviewees head moves. Their is a tracker in motion in FCS3 (not sure about 2) so if you have studio 3 search for tutorials on using trackers in motion, you should find something out there to show you how to do this.
www.afterglow.co.nz
Craig Parkes is offline   Reply With Quote
Old October 15th, 2011, 12:53 AM   #3
You might also want to try Neat Video's noise reducer with the settings high enough to remove dark spots/freckles/nose-aliens...etc. It will soften the image overall, so you might experiment with layering the resulting soft shot over the original and masking only the cleaned area back in. Using a soft edge mask, you might get acceptable results and wouldn't have to keyframe the effect.
Oren Arieli is offline   Reply With Quote
Old October 15th, 2011, 08:28 PM   #4
Never even opened Motion before Craig but I will def check out some tutorials on tracking in motion.
Oren, that sounds intriguing, I will download the demo and give it a try.
Thanks Guys.
