-   Final Cut Suite (https://www.dvinfo.net/forum/final-cut-suite/)
-   -   Should I be able to reconnect media from an external HD? (https://www.dvinfo.net/forum/final-cut-suite/505122-should-i-able-reconnect-media-external-hd.html)
Les Wilson February 13th, 2012 09:23 PM
Re: Should I be able to reconnect media from an external HD?
Also, did you try copying one of the source files to your internal hard disk and selecting it as the file to reconnect to?
Cameron Poole February 14th, 2012 03:56 AM
No I haven't tried that because I assumed that if the project file and all it's predecessors is on the external terabyte too then it won't make a difference.
That said, anything is worth a shot.
I'll give it a shot as soon as I'm home - really hope it works.
Les Wilson February 14th, 2012 06:49 AM
Also, in the grasping at straws category, Try this:
Rename the video file on the Hard disk so it doesn't use "#" in it's name
Do the Reconnect Media
After you click Locate, select Show All Files in the drop down
Unselect "Match name and reel"
Select the file you just renamed
Click Choose.
See if the file is listed in the bottom half of the Reconnect Media Window and the Connect button is selectable
