-   Final Cut Suite (https://www.dvinfo.net/forum/final-cut-suite/)
-   -   Am I going to regret if I'm shooting in different frame rates and formats? (https://www.dvinfo.net/forum/final-cut-suite/513070-am-i-going-regret-if-im-shooting-different-frame-rates-formats.html)
Noam Osband January 1st, 2013 06:26 PM
Im shooting a project with a HMC150 and a Canon XA10. Ideally, the thing will be edited in 24fps but I know I'll want some slo-mo at times. Because of this, I find myself shooting at times with the
HMC 150:
720 60p
1080 24p
XA10
60i
24p
When it comes time to edit all this stuff, am I going to have hell? I use FCP 7 (small chance I'll move up to FCP X but unlikely) when editing. I've never edited a project that has multiple frame rates. I dont know if this is a bad idea or not. Advise me!
Eric Olson January 1st, 2013 08:16 PM
Re: Am I going to regret if I'm shooting in different frame rates and formats?
It is possible to convert 24p to 60i using pulldown, 60p to 24p by dropping frames and 60i to 24p by dropping fields. All of these conversions have an irregular pattern which can cause motion judder depending on the your footage. You can treat the motion judder as an artistic effect, edit around it or use frame rate conversion software based on motion interpolation to reduce it.
What is your distribution? Bluray, DVD, television, internet or cinema?
Sareesh Sudhakaran January 3rd, 2013 09:57 PM
HMC 150:
720 60p
1080 24p
XA10
60i
24p
I wouldn't recommend mixing interlaced and progressive, so except for the 60i everything else is okay, and quite normal. But even the 60i can be okay depending on your workflow and delivery, as Eric has said.
