Old projector flicker and burn at DVinfo.net
Final Cut Suite
Old November 27th, 2002, 05:50 AM   #1
Retired DV Info Net Almunus
Does anyone know if there are any plug-ins for FCP or After Effects that mimic the flicker of an old projector AND also showing the film start to burn once it gets stuck?
Maybe stutter is a better word than flicker...I'm looking for the look of a poorly threaded reel rather than the strobe effect of the early, early projectors.
John Locke
SursumFilms.com
John Locke is offline   Reply With Quote
Old November 27th, 2002, 06:24 AM   #2
Warden
These guys have a flicker http://www.chv-plugins.com/film.html that is supposed to be very nice (I haven't tried it). I had to do a burn effect many years ago. But is was supposed to be comedy so I made it as cheesy as possible. I did a center wipe to a flame with transparency adjusted to reveal the new layer. It was all done before non-linear, so multiple passes of betacam were used to layer.
Jeff
Old November 27th, 2002, 07:22 AM   #3
Jeff,
Thanks...that is a good flicker filter. I'll keep searching for the burn...I'm hoping to get the bubbling-burn effect.
John Locke
SursumFilms.com
Old November 27th, 2002, 08:08 AM   #4
John,
The CHV plugin that Jeff mentioned does a great job. If I get a chance today, I will post some footage from it. I highly recommend it.
Paul Sedillo
Image::Studio
http://www.image-studio.com
Houston, Texas
Paul Sedillo is offline   Reply With Quote
Old November 27th, 2002, 08:49 AM   #5
Thanks, Paul. I'd like to see it.
John Locke
SursumFilms.com
Old November 27th, 2002, 09:48 AM   #6
Paul,
I'd still like to see your footage...but I couldn't resist...I went ahead and bought it. I played with it a bit and you're right, it's great.
Here's something I whipped together real quick...it's so easy to use it didn't take any time at all. I went a bit overboard with the settings...threw in the works...dust, scratches, jumps, flickers...just had a ball. Now if I could just have it bubble-burn at the end instead of fade out, I'd have myself the logo I had in mind.
http://zchildress.com/sursumwho/sf_opslate_oldie.mov
John Locke
SursumFilms.com
Old November 27th, 2002, 03:09 PM   #7
John,
I think you will be happy with your purchase. Hope to get the footage online. If I recall, I might have a film burn plugin. Will check and let you know.
Paul Sedillo
Image::Studio
Houston, Texas
Old November 27th, 2002, 03:11 PM   #8
<<<-- Originally posted by John Locke : Paul,
http://zchildress.com/sursumwho/sf_opslate_oldie.mov -->>>
Dude! That looks great! It has the look of an old film newsreel. Very cool looking.
Paul Sedillo
Image::Studio
Houston, Texas
Old November 27th, 2002, 10:36 PM   #9
Warden
Very, very nice, John.
Jeff
Old November 28th, 2002, 01:23 AM   #10
Thanks, Jeff.
I found a bubble and burn filter...finally. It's part of the Boris Continuum filter set. Unfortunately, it's $400!
John Locke
SursumFilms.com
Old November 30th, 2002, 10:54 PM   #11
Hi John,
I just have found out about this forum. Thanks for the good press!
Bubbles and a Burn-effect.... Good idea. I think I will add these features to the Film-filter. But it will take a little while. There is so much to do these days... X-mas, writing manuals, updates, specials... and tomorrow the new 3D-Explode...
best regards
Christoph Vonrhein
Christoph Vonrhein is offline   Reply With Quote
Old December 1st, 2002, 12:53 AM   #12
Hi Christoph!
You've got some fans here, definitely...with me at the top of the list. The Film-filter is great...within a few hours of buying it, I'd already put it to use.
I'm looking at other filters you've made now, too. If you can come up with the "bubble and burn" effect filter...I'll be the first in line to buy it!
Looking forward to seeing the 3-D Explode filter...I'll check your web site tomorrow to check it out. Also, I'll send you the footage you mentioned in your e-mail.
John Locke
SursumFilms.com
Old December 4th, 2002, 08:55 PM   #13
"Silk and Fog"
XMas is near... so here is the present:
http://www.chv-plugins.com/silkandfog.html
Its a free plugin which creates a nice silk-effect
Go and get it!
best regards
Christoph Vonrhein
Old December 5th, 2002, 06:14 AM   #14
Re: "Silk and Fog"
<<<-- Originally posted by Christoph Vonrhein : XMas is near... so here is the present:
Go and get it! -->>>
Thank you Christoph!
Paul Sedillo
Image::Studio
Houston, Texas
Old December 5th, 2002, 06:33 AM   #15
Me too, Christoph! Thanks!
John Locke
SursumFilms.com
