FCP7 and Mac Air ... at DVinfo.net
Final Cut Suite
Old February 11th, 2014, 01:10 AM   #1
Hi there,
In order to save a few pennies, I am thinking of buying a Macbook Air instead of a full-blown Pro.
As normal, I will be using an external hard drive as a scratch disk but will the Air run FCP7 as normal? I do not expect to be editing an extended version of ‘Avatar' on the Air, just simple cut-cut with the odd transition ... to save a grand, will the Air live up to my expectations?
I look forward to hearing your opinions ...
Stuart
Stuart McAlister is offline   Reply With Quote
Old February 11th, 2014, 06:06 AM   #2
Re: FCP7 and Mac Air ...
FCP7 won't install on my MacBook Air 4,2 as the graphics card isn't supported. So you should certainly check that the MBA you are looking at can actually run FCP7.
FCP7 happily runs on all the recent MBPs.
Simon Thewlis is offline   Reply With Quote
Old February 11th, 2014, 08:09 AM   #3
Many thanks for your reply. I’ll get that looked at ...
S
