Can't seem to capture 10-bit. help? at DVinfo.net
Final Cut Suite
Old November 22nd, 2005, 10:27 PM   #1
Hi,
I'm trying to capture BetaSP through component as 10-bit using a DecklinkSP card. Everything is set to NTSC 10-bit, and export blackmagic 10-bit, but when I open the file in After Effects, the file is listed as "millions of colors".
Oh, and AE is set to 16bpc.
It seems like it's actually on capturing 8-bit.
Any tips on what I'm doing wrong?
Carl Merritt is offline   Reply With Quote
Old November 24th, 2005, 02:08 AM   #2
I fail to see why you think it isn't working. Your presets are 10-bit right? Why does millions of colors make you think you did something wrong? What were you expecting to see?
Look at the clips ITEM PROPERTIES...see if it is 10-bit. If it says it is, it is.
Shane Ross is offline   Reply With Quote
Old November 24th, 2005, 12:16 PM   #3
Because 8-bit color gives you 16 million colors - "millions of colors".
10-bit color should give over 1 billion colors - "billions of colors".
So if it's saying the clip only has "millions of colors", how can it be a 10-bit image?
Old November 24th, 2005, 09:23 PM   #4
Incorrect. Millions of Colors is the most you get...even with the lossless Animation Codec.
That is not what the difference between 8-bit and 10-bit are.
Old November 25th, 2005, 05:11 AM   #5
8-bit images hold 256 colors per rgb channel, resulting in 16.7 million colors, whereas 10-bit images hold 1,024 colors per rgb channel, resulting in 1.07 billion colors.
Could you explain when a 10-bit capture is not a 10-bit image?
Or where could I find information if that is too much to explain here?
I've been searching and have not found any other answer than what I've provided.
Thanks for the replies.
