burner problem in g5 dual 2ghz
My G5 burner seems to work on some discs and not others, even from the same brand fro the same batch.
I sent it in when it was under warranty and i think they upgraded the firmware. Its a sony dvd rw dw qw28a with KAS7 firmware. Has anyone else had any probs, where can i update /downgrade the firware/ If i need another drive what can i get? B.Sundry |
I seemed to have a lot of trouble burning on my G5 also, but then I tried using Roxio toast to burn disc images and that has worked 100% of the time since then.
thanks Nate, ill give it a shot. Anyone else had probs apart from Nate? btw. nice footage from the hd100
| All times are GMT -6. The time now is 03:05 PM. |
