I want to make a full backup of my project on a Removable Hard Drive - how? at DVinfo.net
Final Cut Suite
Old September 14th, 2006, 11:14 AM   #1
Here's my question:
I have over 250gb of footage in my current FCP project file, of which I may only use about 30-40gb in the project's sequence. The rest of the footage was never used (Documentary edit, hence the large amount of throw away footage)
I would like to backup the project onto an external hard drive, but I only want to backup the footage which was used in my sequences - I don't care about backing up the ~200gb extra. Is there any way to do this easily in FCP?
Also, for that footage which is backed up to the new hard drive, I would like FCP to provide a 10 second "buffer" before and after the footage (I.e. if the original clip is 60 seconds long, and in my sequence I use 20 seconds of footage, I would like final cut to store a total of 40 seconds of footage on my backup).
From what I understand. the media manager can be used to do the above tasks. Are there any tricks or anything I should know about using it?
Ari Shomair is offline   Reply With Quote
Old September 14th, 2006, 12:12 PM   #2
I just started learning FCP a little over a month ago so I'm probably not qualified to answer you but- I DO believe "Media Manager" will do this for you.
I even forget what menu it is accessed under but it will export an archived version of your project and even allow you to specify a length in "handles" for the footage you DO use so that you can go back and to minor tweaks on the timing of the edits/transitions.
Lastly, it also gives you a bar graph to signify the ORIGINAL size of the project and the NEW size after the unused footage is trimmed.
Glen Elliott
Cord 3 Films
Glen Elliott is offline   Reply With Quote
Old September 14th, 2006, 02:06 PM   #3
Check out Larry Jordan's article on the subject.
http://larryjordan.biz/articles/lj_m...gr_delete.html
"We've done the impossible, and that makes us mighty."
Nate Schmidt is offline   Reply With Quote
Old September 14th, 2006, 09:34 PM   #4
Originally Posted by Ari Shomair
Here's my question:
Everything you ask for is covered by the Media Manager. A trick? Launch the copied project to make sure the Media Manager actually copied everything. The last couple of times I used it, it did but in previous FCP versions some files were missed. Usually graphic files.
William Hohauser is offline   Reply
