Moving from 4x3 sequence to 16x9 with out recutting at DVinfo.net
Final Cut Suite
Old October 12th, 2006, 08:04 AM   #1
I'm looking for help with a little mistake I made. I cut anamorphic 16x9 footage in a 4x3 sequence. Now I want to transfer the edit to a 16x9 sequence, but when I copy and paste the clips into the new sequence, it adds letterboxing and squishes the footages. It looks like the new sequence is treating the edited clips like 4x3 footage. When I turn the anamorphic box off in the sequence settings, it only makes the problem worse. Is there a way I can pull this off with out having to recut?
Thanks in advance.
Barry Gribble
Integral Arts, IMDB
Barry Gribble is offline   Reply With Quote
Old October 12th, 2006, 08:18 AM   #2
Go to sequence settings and check if it's 16:9 anamorphic. Then go to the footage in the timeline and go to remove attributes, then remove distort and the footage should look fine now! Good luck.
Niels
Niels Neeskens is offline   Reply With Quote
Old October 12th, 2006, 08:21 AM   #3
Boy, that was easy. Thanks so much.
Barry Gribble
Integral Arts, IMDB
