audio transition help at DVinfo.net
Final Cut Suite
Old March 19th, 2003, 09:29 AM   #1
how can i set one audio transition (cross fade) for every edit in my canvas window so that i just hit the effect button once and it transitions every audio edit in the timeline at once? thanks
Gary Chavez is offline   Reply With Quote
Old March 19th, 2003, 01:50 PM   #2
I don't know if I can help (I use a PC) but I know that most of the Mac users will be able to help you more if you tell them which s/w package you are using.
Nathan Gifford
Southern Cyclist Magazine & Productions
For quick answers try our Search!
To see me and Rob Lohman click here
Nathan Gifford is offline   Reply With Quote
Old March 19th, 2003, 01:53 PM   #3
S/W ? OSX, FPC 3. G4 DUAL 1.25
Old March 19th, 2003, 02:11 PM   #4
OK. I'm not FCP expert. What are you trying to do with the cross fades? Generally, you have to place each cross fade in the timeline or sequencer. Next you mark the section you want to render, or mark the entire project, then render the audio or project.
Nathan Gifford
Old March 19th, 2003, 03:39 PM   #5
SORRY TO BE SO DENSE. I COME FROM TAPE TO TAPE DAYS, THIS IS KILLING ME. HOW DO I SET ALL THE IN POINTS AT ONCE THEN?
Old March 19th, 2003, 10:25 PM   #6
Warden
I'm not sure what you're trying to do. I use the down arrow to move to different edit points in the timeline and use Command_Option_T to drop the cross fade on the edit. Double clicking on the effect will open up the duration dialog window in which the duration of the effect can be changed. I'm not sure that helps or is what your trying to do.
Jeff Donald
Carpe Diem
Old March 20th, 2003, 07:15 AM   #7
yeah, im doing all that and everything looks good, just will only drop in on transition per sequence, or timeline. could it be that i have transition "default" set?
Old March 20th, 2003, 07:35 AM   #8
Warden
If your wanting to pick from several transitions, designate them as favorite and they are available from the button on the right under the viewer (looks like a piece of film). You could have several different effects there that you use most often.
Jeff Donald
Carpe Diem
Old March 20th, 2003, 12:59 PM   #9
Gary,
Are you trying to insert transitions on all edit points with one command?
I don't think this is possible in FCP 3. Certainly would be good in some circumstances.
Usually, you insert with transition as you lay the material in the track. For edit points that you create by cutting, you'll have to add the transition by dragging or as Jeff indicated.
Michael A Westphal
Michael Westphal is offline   Reply With Quote
Old March 20th, 2003, 01:01 PM   #10
yes, that's what i was trying to do, sorry if i cant explain myself well. Seems to me to be an elementary edit function, but then i know nothing and am learning very slowly. thanks for the responce.,
