is this possible...Mac to PC? at DVinfo.net
Final Cut Suite
Old November 19th, 2006, 05:16 PM   #1
Wondering if I can go straight from my Mac to PC by playing a sequence in FCP using firewire?
The setup I have now is connecting a firewire cable from FCP to my VX2100 camera (External Video>All Frames) and recording the video onto miniDV tape.
Then I go firewire from the camera to my PC and play the tape to capture it on my PC editing program.
Wondering if there is a way to bypass the camera and capture straight from the FCP timeline to my PC?
I am basically hoping to take out the step of recording it onto tape?
any thoughts, advice??? thanks in advance!
Jay
Sony VX2100 cam; FCP 5.0.4
Jay Voog is offline   Reply With Quote
Old November 19th, 2006, 05:30 PM   #2
Interesting idea... sound feasible.
I'd give it a try!
Nick Weeks is offline   Reply With Quote
Old November 19th, 2006, 05:45 PM   #3
when i have tried going from my mac to pc with a firewire connection, it doesn't recognize my mac, so therefore when i try playing the sequence, the PC doesn't see it.
so i am just wondering if anyone has ideas how this could work...would i need another device? card? something?
is there a way to network the 2 computers through firewire?
hoping someone has an idea without needing some device to bridge the gap (skipping the camera).
Jay
Old November 19th, 2006, 06:02 PM   #4
You could boot your mac in firewire target mode (I believe you hold down the T key and restart). Then your mac will behave just like a firewire disk. However, it will be a MacOSX disk which your PC won't recognize without some special software. And then you would have the issue of different file formats, etc.
Also, if you experiment plugging the mac and pc together via the firewire ports you might have some concern about blowing the port on one or both of the computers. I don't think I would mess with that personally.
If you use an external firewire drive you could format it as a PC disk and the Mac will recognize it without problem. Then you could plug that disk into your PC and copy any files you want.
Old November 19th, 2006, 06:16 PM   #5
thanks for your comments Boyd.
i was actually trying to think of a way to play the sequence and record it live on my PC instead of just transferring the quicktime movie file, but not sure if that would be possible based on your comments. i don't come across too much on the technical side of things, so thanks for pointing some things out to me, i appreciate it.
Jay
Old November 19th, 2006, 06:33 PM   #6
You might could pull this off with 2 DV cams if you have them... just send the Mac output through FW to one cam, take the video out from that one to the input on another DV cam connected to your PC by firewire. I think it would probably look OK using s-video, but I wouldn't do composite.
Old November 19th, 2006, 11:11 PM   #7
The answer is most likely no. While running the NLE programs both your PC and Mac are looking for a FireWire device that has the electronic signature of a DV (or HDV) deck to feed the video signal to or record from. This is why the programs don't mistake a FireWire drive for a videodeck. Neither of them are able to recognize each other as both are computers looking for devices on a firewire bus. I'm sure someone could (or maybe has) create a hack that overrides the signature. I'm not sure if you would want to use with it as I could imagine a lot of problems with a computer behaving as a proxy video deck.
Stay with the tape method or work with QuickTime files.
Old November 20th, 2006, 02:00 AM   #8
IP Over Firewire may be another option for you. Mac to Mac it works fine. XP supports the protocol, however I've never tried connecting a PC and Mac together using Firewire. In THEORY it should work.
See: http://developer.apple.com/hardwared..._firewire.html
Chris Hocking is offline   Reply With Quote
Old November 20th, 2006, 02:02 AM   #9
Confirmed. Yes it can be done.
See:
http://www.macosxhints.com/article.p...31112091634533
http://www.lifehacker.com/software/n...ire-173973.php
Old November 20th, 2006, 08:16 AM   #10
Images: 1
Originally Posted by Chris Hocking
I have done it without any additional programs. I have connected my Mac and Compaq notebook together via FW. Works great!
Jay's idea is an interesting one. On the PC, you would need to be running an application such as Scenealyzer which does A/V capture via FW. I'm going to give it a try and see what I come up with.
-gb-
Greg Boston is offline   Reply
