FCP can someone help? at DVinfo.net
Final Cut Suite
Old January 6th, 2007, 07:17 AM   #1
When i click bach capture it shows the clips that i want to capture but it also shows some other clips that i have no idea where they came from, can someone tell me how to get rid of these random clips from the bach capture window?.I have tried to get rid of them but backspace and delete don't work so i have to skip them when i capture.
Any help would be great, thanks in advance.
Andy.
Actor: "where would that light be coming from?"
DP: "same place as the music" -Andrew Lesnie-
Andy Graham is offline   Reply With Quote
Old January 6th, 2007, 06:54 PM   #2
If you select the clips in the browser that you want to copy, in the batch capture window you can choose to only capture selected clips. Of course if you've already done that than I don't know.
"We've done the impossible, and that makes us mighty."
Nate Schmidt is offline   Reply
